Group: DynoMotion Message: 7111 From: az9633@ymail.com Date: 3/24/2013
Subject: Re: Inverse distance KCNC settings
I thought I was considering the scaling but The devil is in the details! Because this is not my first machine (but is my first Kflop) I just scanned the information and used what seemed to make sense.
I set up the Inverse distance at the 1 inch setup in the example which I intuitively thought would have applied to a KCNC setup.
I proceeded to the KCNC which is set up in inches and I thought all would be roses. I finally figured out that the KCNC wants the .001 inch increments and not the 1 inch in the example.
AZ
> Hi AZ,
> Depending on how you scale the output you need to set the speed appropriately for that scaling.  So for example if your speed is set at 100 units/second it makes a big difference if the units are inches, or full steps, or cycles.  I prefer to leave the invDistPerCycle set at 1.0 so that KFLOP operates in cycles.  Then set the Velocity, Acceleration, and Jerk in those units.  Also set the resolution in the PC application.  Sounds like you didn't consider what speeds, acceleration, or Jerk you were attempting.
> Fro'm: "az9633@..." <az@...>
> Sent: Saturday, March 23, 2013 2:06 PM
> Subject: [DynoMotion] SnapAmp settings
> I was setting up a SnapAmp for a 1.8 degree step motor following the instructions for setting the Inverse Distance parameter. The example of 1000 full steps per inch was exactly how my machine is set up. 5 turn per inch screws with direct drive. So I set it to 250 and the motor only growled but didn't move. What I found was the setting actually had to be set to 0.250. Did I miss something?
> Thanks,
> AZ
